3 gang wiring problem
20 May 2019
I am trying to add an outdoor light to a 3 gang 2 way switch. On switch one is a hall light 2 way and on switch 2 is a landing light 2 way. Both connected and working fine.
When I connect the outside light to switch 3 however it does not function. I have bridged all the COM terminals and wired the light as the others - neutral to L1 and live to L2 with no result. I then realised that I did not need this light as a 2 way so wired it as one way - live in COM and neutral in either L1 or L2 -neither has worked. Is it possible please to have some guidance on where i am going wrong eith this? Many thanks in advance
Regards
Noelo
There's no neutral at that switch, unless the black is connected to something somewhere else, nor are there any earths for that matter. I'd leave the bag of nails alone and get a professional in and pay the <£100 they'd charge.
You don’t have neutral in your light switch pictured, you can’t just wire in a new light to the switch. Those black wires you see are not neutral, they are switched lives or loop wires to the other light switches. Also no earth as mentioned above, and it looks like you have metal faceplates. Sounds like you need a Pro, adding a new outside light is notifiable work anyway.
Thank you all for your advice which I will take and get this sorted properly. I thought this was going to be an easy install but did not realise tbh that this was notifiable so again thank you for your help
I do wonder why there is no earth wire? looks dangerous
definitely get a professional in
good luck
Many older houses don’t have earths on the light circuit. It’s a not a problem until you switch to metal faceplates. Double insulated fittings don’t require Earth either.
The 3rd wire on the right. Does the black wire actually attach to anything?
Remove the brown and put into L1 and join the blue to the black neutral on the 3rd wire as that seems to be the feed wire.
