Caporegime
- 9 Mar 2006
- Surrey
Classic GW sculpting quality
Their faces are getting worse and worse.
Their faces are getting worse and worse.Classic GW sculpting qualityTheir faces are getting worse and worse.
How odd, that's what I said when I first met you!I must admit there are hints of angry cross dresser and pouty homosexual but pretty certain it's a woman.
I was nice when I saw it in person, you don't need double-niceness!At least be nice about my model at the same time as being mean to me![]()
Treated myself to a forgeworld hellforged leviathan for my chaos army.
Lovely model but won't be getting anymore fw stuff. Resin is horrible to work with. The arms are magnetised and that was the easiest bit
What would i need to buy to start playing this? I was after something like space hulk (which i remember as as a kid) but it seems that too is no more and kill team seems the next best alternative.My partners son is getting into Warhammer 40K and loves painting them. I would like to get him playing too and kill team looked a good option given he can use the models he already has but doesn't need to spend a fortune on a massive army. However, the starter set is no moreWhat would i need to buy to start playing this? I was after something like space hulk (which i remember as as a kid) but it seems that too is no more and kill team seems the next best alternative.
Re resin, I don't mind working with good resin myself, but pretty much every forgeworld resin kit we've ever bought has had issues (with the exception of a greater brass scorpion), ranging from my brother's great unclean one that 18 months after he finished painting it (he spent god knows how many hours and got it to a brilliant standard) he got it down to use again and found it was oozing uncured resin from where he'd pinned it to the base which had ruined the base and parts of the paint job*, other issues have included panels that were thinner than tissue paper (orc truk conversion kit), bits bent completely out of shape, with holes in them, and we just received some Warlord weapons for Adeptus Titanicus which are not cured properly and have a very thick coating of release agent on them (which apparently is likely the reason the resin hasn't cured properly). It's not just the normal nasty release agent, this is visible levels that almost feels like a slick yet tacky gel.What didn't you like about it? The process is definitely longer when having to clean the resin, trim and potential fill/sand/bend any parts however personally I get enjoy the modelling aspect so found it a fun challenge.
I've built a Contemptor, Leviathan, Sicaran and a couple of quad mortars and they've been fine for the most part. The Sicaran needed a bit of sanding and filling work mainly on one of the tracks due to the position of the gate that needed to be removed which I'll admit was a bit of a bugger to sort.
I've got a couple of bigger models to do yet but going to get a bit more experience with some other bits I have first before I tackle those.
(between two of my friends they've got something like 3 28mm scale titans - iirc warhound, phantom and something else, several of the resin flyers, the second largest Tau flyer, 20+ Mortalis tiles and that's just the big stuff, needless to say they've spent a lot of time on the phone to FW getting replacement parts sent out).I'm currently watching the same battle report. I know Liam. Top guy.
