Powershell or similar...
10 May 2012
I am trying to search a list of folders containing XML files amongst other things. I am only concerned in searching a specific version number contained in these folders. Rather than using the Windows in built search which is throwing up false positives, can anyone think of a powershell command or search that can assist purely searching for said version number.
Thanks - any advice would be appreciated
Get-ChildItem -Path C:\meh -recurse -Include "*.xml"
it's almost always better to filter before the pipe so that you're not passing EVERYTHING to the next step.
