- 24 Nov 2018
Hi all,
I've been playing around with my 4790k, learning the ropes of overclocking and trying to get the most performance from my rig.
I've looked through several guides and threads regarding this cpu, I think I'm in line with what others are getting, but I want to take my cpu further.
My rig and current stable OC is:
Asus z97 pro gamer
BCLK 104
System agent 1v with offset +0.23
IOD offset 0.225
IOA offset 0.22
I7 4790k @ 4.8ghz (4780) 1.275v vcore, 1.95 vcin
4.6ghz (4560) cache @ 1.26v
Cooler - arctic freezer 240 74 CFM using 4 fans in push pull config
Kingston beast 2080mhz 9-11-11-27 @1.7v
The voltage used to run at 4.8ghz seems to be on the good side of average, but my limiting factor is heat.
This current OC hits 85C absolute maximum during prime95 (266), which means it runs around 75C peaks during normal usage, which I'm happy with. However if I try to give it anything over 1.3v vcore, I start hitting temperatures in the 90s during the same prime95 (266) runs.
I'm not sure why my temperatures are so high though, I've seen some people saying they've given theirs 1.4v, and able to keep it low 70s with mid-high end air coolers, yet my cpu starts to burn up with anything over 1.31v on water. Additionally there seems to be a delta of 10C between the hottest (#1) and coolest (#4) cores during stress testing, where core 4 can be in the low 80s whilst core 1 reaches low 90s.
I've been able to 'stabilise' 4.9ghz at 1.32v iirc, and by that I mean it passed hyperpi, cinebench, and real bench, but running prime95 266 would scare the crap out of me with the temp on core 1 hitting 94C.
I want to get that mythic 5ghz people, I believe this chip has the potential, I just need to be able to cool it down somewhat, any suggestion of things I can try would be most welcome!
Thank you,
M
Asus z97 pro gamer
BCLK 104
IOD offset 0.225
IOA offset 0.22
Thank you,
M
