After reading what i can find i am not really understanding any better what i initially started out to learn.
So a few questions from me and i hope you can clear things up.
1. I understand some motherboards are getting a bios update to support the new Ryzen processors, But
i have read that it may also allow pcie 4.0 support as well, will it be a limited form of support.
2. If the ryzen processors have 40 lanes, will it still use 40 lanes in a lower than x570 motherboard.
3. If all the new x570 motherboards have a cooling fan on them, and a bios update allows an x470 to
do more or less the same, would a cooling fan need to be fitted to the x470 motherboard.
3. Should i just get an x570 motherboard and forget all about the x470.
thank you.
thank you.
