Nose Wax the Turk Barbers Use
If nose hair is so vital to filter nasty things in the air, what filters when I breath in through my mouth? (When I cycle, for about an hour I'm breathing huge quantities of air through my mouth. Shouldn't I be dead now?!)
Funnily enough, Amazon had this on offer yesterday so I thought I'd try it at just over £6.
I don't think waxing is actually recommended. Get a trimmer and you can do your ears too. Oh the joys!
If you are only using it for nose then it may well stay hot enough for that application.
You really need a warmer for sustained heat for larger applications.
My question would be why can you use a trimmer?
Only a sadist would wax their nose.
I have a trimmer but, it tit can still see the hair if you happen to catch a glimpse up the way. I just don't like nasal pubes, they're horrible and I want rid.
they are there for a reason. they help prevent colds, etc.
fair enough. just get some wax off amazon. there are literally hundreds of different types so do your research as to what is best for sensitive areas.
you may also want to check which may cause allergic reactions too.
These are available on The Rainforest site..
The what site?
Wait, people actually get their nose hair waxed at the barbers?
I use a local Turkish Barber and it's part of the total cost - £20 for hair cut, nose hair waxed, eyebrow hair trimmed, ear hair flame treatment and a Turkish shave. A nice monthly treat for myself. When attempting to get wifey in the mood, being groomed usually helps my cause :D
