Mac Pro 2019
30 Dec 2005
8-core Xeon, 32GB memory, Radeon Pro 580X, 256GB SSD. Starts at $5,999 :eek:
https://www.apple.com/mac-pro/specs/
8-Core
3.5GHz Intel Xeon W
8 cores, 16 threads
Turbo Boost up to 4.0GHz
24.5MB cache
Support for up to 1TB 2666MHz memory
12-Core
3.3GHz Intel Xeon W
12 cores, 24 threads
Turbo Boost up to 4.4GHz
31.25MB cache
Support for up to 1TB 2933MHz memory
16-Core
3.2GHz Intel Xeon W
16 cores, 32 threads
38MB cache
24-Core
2.7GHz Intel Xeon W
24 cores, 48 threads
57MB cache
Support for up to 2TB 2933MHz memory
28-Core
2.5GHz Intel Xeon W
28 cores, 56 threads
66.5MB cache
Two USB 3 ports
Support for USB-A (up to 5Gb/s)
Two Thunderbolt 3 ports
Support for Thunderbolt 3 (up to 40Gb/s)
Support for USB-C (up to 10Gb/s)
Support for DisplayPort
Two 10Gb Ethernet ports:
Support for 10Gb Ethernet performance over copper cabling
Support for Nbase-T industry standard: 1Gb, 2.5Gb, 5Gb, and 10Gb Ethernet link speeds using RJ-45 connectors
15 Sep 2009
Manchester
I'll never need one of these, but I can dream of being able to afford one. But they're going to be damned good for actual professional use so no doubt all the Videographers and Photographers will be all over them as well your average semi-competent Youtuber who decides that he needs 1.5TB of RAM to render 4k for his generic tech reviews.
20 Feb 2011
The basic model is great apart from the SSD size. Seriously Apple - WTF? A 6 grand machine with a 256Gb SSD? That’s just plain naff.
233
233
21 Nov 2004
Wishaw
When you consider the cost of professional grade workstations its not that bad price wise,
charging an extra 1000 dollars for the monitor stand is lolworthy though,
Apple really has went all in with this and offered something that pros will be all over,
16 Jan 2005
South Wales
People saying how good this is are probably unaware about the 32 Core Threadripper for 1.6K
Possibly, but unless you go down the route of QEMU with hardware pass through and an OSX VM, or some really funky Hackintosh setup you aren’t going to be running Final Cut or Logic, which I suppose is what this machine is really aimed at.
I think it’ll be massively overkill for most people, but gets you shiny cheesegrater bragging rights. I want one, but I certainly don’t need one.
18 Oct 2002
West Midlands
I didn't see any mention of what drive bays are available. The old Mac Pro had plenty of them so it'll be interesting to see how many this has.
Don't see it having any 3.5" drive bays, if you want more storage you'll be able to add more NVMe either directly to the PCI-E slots, maybe a couple of 2.5" U.2 bays (low chance) or M.2 drives directly to the main board or using a 2-4 way PCI-E adapter card.
If you need spinning rust directly attached in large quantities you have TB3 or 10GBe to a NAS or SAN, what more so you need?
13 Jan 2003
Nice unit with CPU and GPU for compute workloads such as AI etc.
Use of GPU in API for acceleration is now commonplace and the RX Vega based core has a better double precision which is a good bonus.
5 Nov 2010
Hertfordshire
I’m going to have to think of something else for our concept studio at work now. I can’t justify that price. We bought the ‘trashcans’ for £3200 (ex VAT) each and have been waiting for this new revision, but we’d be paying double this time around.
