9900K 5Ghz -1,230V Max 68C / Delid / der8auer Intel 9th Gen. OC-Frame
28 May 2019
I finished my new system and used full body custom loop
9900K @ with Delid and der8auer Intel 9th Gen. OC-Frame
My System ;
- 9900K @ / 1,250V / Delid / der8auer Intel 9th Gen. OC-Frame
- Asus Rog Maximus Xi Formula Z390
- 32Gb Corsair Dominator 3200Mhz
- Asus Rog Strix Gtx 1080Ti OC Edition
- Evga SuperNova 1000W P2
- Evga P2 White Power Supply Cable Set (Individually Sleeved)
- Samsung 970Pro 512Gb
- Samsung 950Pro 512Gb
- Samsung 850Pro 256Gb
- 9 Corsair LL Rgb Fan 120MM
- 1 Corsair LL Rgb Fan 140MM
- 3 Ekwb Vardar Evo
- 8 Corsair Rgb Led Strip
- 2 Corsair Commander Pro
- Nzxt Internal Usb Hub
CustomLoop Parts ;
- EK-Velocity RGB - Full Nickel
- EK-FC1080 GTX Ti Strix - Nickel
- EK-FC1080 GTX Ti Backplate - Nickel
- EK-XRES 140 Revo D5 RGB PWM
- 2Pcs EK-CoolStream PE 360 (Triple)
- Bitspower In-Line Filter
- Thermaltake Pacific Temperature Sensor
- Thermaltake Pacific Flow Indicator Two
- 16mm OD Tubing
- Many EK-HDC Fitting 16MM , Angeld Adapters , Extenders&Spacers , Special Connectors , Plugs[/B]
https://ibb.co/sgNpg63
https://ibb.co/sVCp2LD
https://ibb.co/42dCRSc
https://ibb.co/yX26Jc0
https://ibb.co/qDgN1Sy
https://ibb.co/nw2Jtgt
Looks a good chip. Mine will do 5.4ghz but at that point it’s near on impossible to cool even with custom loop, liquid metal and polished IHS.
I have mine at 5.2ghz 24/7 and it stays at around 70c maximum.
Awesome, I want to go 9 series, but swore I wouldn't touch the 8700k for a couple of years now!
Glad bawhum and kd43xf7596 haven't came in here to question why it's not a Ryzen.
My System ;
- 3 Ekwb Vardar Evo
CustomLoop Parts ;
- 16mm OD Tubing
Where did you get your quicksilver from?
