Well, these make more sense:
https://videocardz.com/80966/amd-radeon-rx-5700-xt-picture-and-specs-leaked
Water coolers. There's nothing more annoying that waiting for blocks for custom PCBs and then you pay a premium for a beastly air cooler you're never going to use. Give me a reference card with a cheap-ass cooler I can bin any day.
Also, I know a lot of people who crank their headphones up so loud they can't hear a blower cooler screaming away in the background, so noise isn't an issue for them.
Blower fans are not that bad tbh
It just takes the users to know the limits, take my VEGA 64 for example if I aim for a reasonable clock speed that is 1500 then my temps and noise level is actually quite good. But if I start punishing for unrealistic targets then the GPU will get hotter and more noise will be heard.
Blower fans actually are better for the overall system also because they push the hot air out the case rather than dumping it into the system and having the CPU and Motherboard and PSU etc heat up.
I don't agree. With a single blower, your videocard PCB experiences significantly worse thermal density upon itself. Because of the configuration itself, you get less heatsink volume, and all the heat accumulates there.
With 3 axial fans, you get lower thermal density and much faster heat exchange between the components on the videocard PCB and the surrounding area. Your case has several more axial coolers to help.
See, if the blower cooler was double, like two smaller blower coolers and somehow larger heatsinks, maybe it would be the more efficient design.
Blower coolers are indeed bad and must be avoided at all cost like the plague. These coolers introduce low ventilation efficiency, which leads to worse thermals for the components on the PCB, less gaming framerates performance and last but not least they cause unbearable amount of unpleasant sounds coming from the air that tries to escape from the little furnace out there.
Meh, from 1 to 10, I give blower coolers a 0.
You agreeing and disagreeing with yourself. Re-read what I said not once have I said blower fan is better than a custom fan config. But what I will repeat again is you making out that blower fans are so much worst than they are! It really comes down to the user and realistic expectations!
Again I will say it out for you!
If I take my VEGA 64 blower fan and try and reach clocks of 1600+ all I doing is hitting unrealistic expectations, in turn, a hotter GPU and more noise levels! If I keep it at clocks that a realistic like 1500 then the GPU remains cool and noise level is on par with most coolers. My GPU doesn't go over 70c on the core and 80c on the HBM and noise level is good "Obviously what my noise levels vs yours will be much different"
Even worse is that every reviewer will get an awful blower card, then Navi will get a reputation for being hot, loud, and underperforming, which will become the baseline benchmarks when comparing against nVidia cards.
Doesn't matter that X months down the line you'll be able to get a cool/quiet/better performing card, all people will see is the 'stock' card performance.
They did the same thing with Vega, and 480, and 290...
A decent noise cancelling headset solves all those issues any how .
You say that blower coolers have lower thermal dissipation capacity.
And this is enough said.
10pm GMT right? The amd e3 thingy?
I did? Where? LOL
lower fans just require users to have realistic expectations.
Depending on the size of the case and its fans a custom cooler on a GPU putting all the hot air into the case can actually affect other hardware like the CPU/Motherboard and even the PSU can get hotter.
Here:
and here:
I disagree. You conveniently skip the fact that with axial coolers there is less heat and lower temperatures overall. What with a blower cooler is heat, with an axial cooler is just warmth.
I just can't believe they've shot themselves in the foot with the damn blower cooler again! Explains why the 'game' clock is so much lower than the boost clock. Teased us with the R VII axial cooler then ripped it away Guess it's mod with AIO or wait months for the partner designs. *sigh*
Ahhh, Google told me 3pm pt is 10pm gmt... That's why I was checking, I thought it was 11pm as well11pm iirc, 3pm Pacific Time
