** The AMD Navi Thread **
25 Nov 2011
The KOP
24 Jun 2016
Hartlepool
Permabanned
2 Sep 2017
What? I think you completely fail to read what I saying!
You can have two VEGA 64 GPUs one blower and one triple fan running at the same speed and voltage they will both give of the same amount of heat! That heat doesn't just magically disappear! Core Temp and HBM Temp is only part of the story, the TDP of the GPU remains the same its still 400w worth of heat that must go somewhere.
I don't think you actually believe what you've just typed.
See: Gigabyte explains it for you:
The heat dissipation performance is enhanced up to 33% than the reference card https://www.gigabyte.com/Press/News/1294
25 Nov 2011
The KOP
Again WOW!
Cooling the Core = higher clock speed you still have the GPU outputting the same amount of heat LOL
GTX 1080 = 180w - CORE temp will still be around the same as VEGA 64
But VEGA 64 = 300w Again the core will be the same "Depending on the cooler used"
But guess what GPU outputs the less overall heat?
A perfect example is this video! Note the GPU core temp but look at the total system power! = More heat into the room! It doesn't MATTER what the GPU cooling is even if you water cool the TDP of the GPU doesn't change and the heat output remains the same.
Edit
This is my last reply to you! Thread is getting abit OT now
HeX
HeX
20 Jun 2004
Huddersfield, UK
Shankly is right regarding the heat; a better cooler doesn't reduce the amount of heat a card produces it just removes it more efficiently, there's still X Watts of heat dumped somewhere. That's the 33% improved cooling Gigabyte is talking about, they are saying their cooler removes the heat X% faster/more efficiently than the stock card.
Permabanned
2 Sep 2017
But I didn't say that the TDP didn't stay the same. It stays the same but over a much larger surface and volume of air.
I have no idea why he argues about the TDP when it's completely irrelevant.
Permabanned
2 Sep 2017
And you said GPUs experience 'higher thermal densities' under a blower cooler. Cooling doesn't change the thermal density - Voltage and clockspeed do.
This is wrong.
Voltage increases the thermal density while good cooling decreases the thermal density.
And by thermal density I mean the average temperature over the PCB surface.
18 Feb 2015
bru
bru
21 Oct 2002
kent
I said this a few pages back, dxr is locked to nvidia until next year when it is free reign when the agreement runs out, no one believed me but I don't care, I know what's up. Raytracing with software and hardware will be for both companies
And again we would like to see some evidence of this exclusivity deal.
DXR is part of Direct X and is vendor agnostic.
Caporegime
20 May 2007
Surrey
So judging from that slide it is basically ~ 2070 performance, possibly just edging it on average by a few percent.
It is going to be all about the price.
If it is under £300 i think they will be on to a winner. Anymore and its a massive disappointment quite frankly. If it more like around £400, why would you not just get the 2070? It has ray tracing and probably (just basing this on speculation) better power usage.
If it is under £300 i reckon i will get one.
30 Jan 2007
PA, USA (Orig UK)
4K) They are talking about heat output, you are talking about heat at the chip. Please get aligned so this can continue normally...
So... Starts at 6pm for me. Might skip the gym to watch lol. Not expecting anything miraculous, but just want to get an idea of whether it is worth buying. Tired of the ridiculous prices and I don't want to invest in older tech (570/vega56) tbh.
30 Jan 2007
PA, USA (Orig UK)
Will they say "cheaper for better performance", "we are better so pay more" or " we give.better overall perf for the same money". Pick your winner....
26 Sep 2017
In the Masonic Temple
Yeah this, either price it less and be champions of us all, or same price with ray tracing (not going to happen) If AMD mess up and price it the same they are rediculously stupid, like SUPER rediculously stupid
It's almost as if the price difference will be what RTX is worth
HeX
HeX
20 Jun 2004
Huddersfield, UK
Yup, if that's accurate it all comes down to pricing. Especially if the rumours of Nvidia price drops are true... Otherwise as you say why not just get an already available 2070 with RT...
