- 12 May 2011
- Southampton
I have an old Dell. It has an annoying problem where it turns itself on automatically after I shut it down. It is not a windows / update problems as it did it before there was even an HDD installed. It is about 5 - 10 minutes after I turn the PC off.
It could be related... it will also turn itself on automatically at the moment I plug in the power cable (but it then turns itself off after 10 seconds). The power switch works fine and isn't permanently pushing the PC on.
In the BIOS the power saving modes are
Power loss recovery - off
Auto Power On - off
Low Power Mode - Off (ON has more functions are turned off when the system is hibernating or switched off - Ive turned it on to see if it makes a difference)
Remote Wake Up - Off
Suspend Mode - S3
It's a very basic set up. I've disabled everything that isn't used such as LAN, serial, parallel, one of the SATA ports.
Auto Power On - off
Suspend Mode - S3
