Permabanned
- 11 Jan 2019
- bedlam
if you need a system now then yes 2600 or a 1600x for about a bit less £££'s
I've just snagged a 2700 for £150 off fleabay. Combined with the msi tomahawk and some decent 3200mhz ram £180 for both that's a very respectable 8 core machine for £328. When you factor that the entry level 6 core 3600 will likely be £250 alone after gouging i don't reckon that's bad. Plus it gives me the option to jump on zen 2 at a later date once the prices are not as mental
Yup, and in all likelyhood you'd have seen no difference in gaming if you'd have waited for Ryzen 2.
Ryzen 2000 has been a huge upgrade for me. I think AMD have **** the bed with the pricing on these new chips
Where I said "you" I should have said "I" I'm talking from my experience of my own setup, bit harsh saying it's nonsense though, what are the gains on moving from Ryzen 2 to 3 in gaming? Or even first gen. No one knows yet but is it worth the cost? Doubt it.
I waited for 3000 series CPU's to be announced, and seeing that the 6core/12thread 3000 series CPU will be at least £200 to start with makes me want to just go for a 2600 paired with something like a B450 Tomahawk as I'm on a budget. Will think about dropping in a 3000 series CPU in a year or two time (if it's even necessary).
Yeah seems more and more likely this is the route I'll take.Well if you are on a real budget then the 2600 is a great deal, <£250 will get you a good B450 board, 16GB DDR4 3000MHz, and the 2600 with a cooler. With something like the MSI Mortar and the very capable VRM it leaves the option open to putting in a cheap 3800X, or 3900X further down the line, or if you are lucky even a Ryzen 4xxx CPU.![]()
