Definitely not I remember reading a long thread about it. Can't say if the OP was lying or not though I can't remember it that well.
So I lapped the heatsink to try reduce the temps but it's not helped so it must be the broken capacitors causing increased temps.
Question : do I need solder pads or can I just makeshift the connections with some solder? (surely it's the same difference)
Solder pads are kinda needed. The pcb connections are with small tracks running along the fibreglass – to electrically connect a component to these tracks you need a pad for the part’s legs to be soldered to. If the pad has been lifted/removed then you will need to solder to the track that went to that pad – probably meaning scraping away some solder-resit/conformal-coating that’s on top of the track.Question : do I need solder pads or can I just makeshift the connections with some solder? (surely it's the same difference)
New GPU time. I hear the 2080Ti will be 100 quid cheaper soon so you might get a bargain
This thread reminds me of that guy that literally filled his pc with water to watercool it.
link
no way! hahaah
I don't know it's years ago. Maybe someone else will remember, I don't even think it was directly on this forum.
So, erm, find the track that originally went to the pad, use a scalpel and v v carefully scrap away the coating without damaging the track, so you can solder to it. tin and solder as normal, and check with a multimeter against the other end of the track, at either a solder-pad or test point.
If that pad just goes to a via (small hole running through the fibreglass to connect one side of it to the other), then you’ve got more fun/problems…
Solder alone wont stick to the pcb board, so without a solder pad or track, you've got a challenge... If you try "makeshift" and somehow create a massive solder-blob to bridge a gap where there used to be a pad, then it won't have the strength of the original pad and it probably will require so much heat from the soldering iron that you could goose something...
(has visions of solder being melted everywhere, accidentally bridging existing pads, damaging components, etc...).
finally - what anti-static protection are you using when handling this pcb?
This is what I was thinking of.
https://www.google.com/search?q=PC+...ome..69i57.10999j0j7&sourceid=chrome&ie=UTF-8
This one's new
That second video with the 3M liquid is clever. Boils at 49c so perfect for cooling PC components.
You could have used electrically conductive glue to make the electrical connections, but then you run the risk shorting the components if you get sloppy with it. Keep the Bostic for component stress relief.
https://uk.rs-online.com/web/p/products/9185002/
Is there a cheaper product from that shop that'll work?
Crazy stuff, It's a shame it's so expensive, you could create a great fishtank style system.
You could even have a tank in a tank so you could have real water and fish swimming around it.![]()
