- 21 Sep 2018
I wasn't meaning PCIE4 - they all have that. All of them are pcie4, they all have a x570 chipset, they all support DDR4 ram and they all support Ryzen 3000. It's the smaller things that divide them.
I had a quick run down - the Formula obviously has better VRM, it's also a board that needs a custom loop to cool the VRM.
As I suspected, the Tuf only does 1g LAN, the formula 5g. The formula has in built wifi, the Tuf it seems does not. The Formula has nearly triple the amount of USB ports and the Formula can do 2 pcie4 GPU's in SLI, while the Tuf can only do 1 gpu with pcie4. While I dont care about the next one, but the Formula has a higher model Audio controller and various overclocking features the Tuf doesn't it (not sure that matters).
Some of these things may be important to people - for instance the Tuf would never cross your mind if you are going to SLI
My point is, one does not need to spend so much more on AMD more than an equivalent intel i9 system to match it like some are trying hard to portray.
