I feel like there isnt many people understanding what AMD were actually proving when its actually quite simple.
Nobody in their right mind will use the Slow preset @1080p using 10k bitrate on a single PC stream setup before July 7th.. and if anybody already does this then its an absolute rare case with an expensive Intel HEDT or Threadripper setup.
OBS loves cores!
AMD are showing that those settings can be done now at a lower price than putting together a Streaming PC which usually costs way more.
Its as simple as that, like i said in his YT comments, Steve jumped the gun and should have waited to get the 3900X in his own hands and tested himself with the exact same OBS settings on both.
Gotta remember that neither GN or AMD said which OBS Profile and Tune settings they used, these 2 settings together can cripple a CPU with the better quality presets, and this is how i think the 9900K was crippled in the demo (even though AMD may have used an 'easier on the CPU' Profile and Tune option on the 3900X)
.. but then Steve may have done this with the 9900K in his video
One more thing, in the demo AMD were showing what the viewer sees, not what OBS looks like.
I actually ran the same settings with my 2700X with only the bitrate lowered to 6000kbps and yes.. it looked terrible with GTA V
OBS loves cores!
