- 16 May 2007
3200mhz is not obtainable for me either, i've tried voltage all the way to 1.45v with loose timings, it posts but instantly gives errors in memtest, dial it down to 3000mhz however and it will rock 13 13 13 13 34 42 all day long, it perplexes me greatly
Would this be the cpu's IMC causing this or the motherboard somehow (see sig)
This may not be your problem as you have 2 x 8GB but I found going from 2 x 8GB to 4 x 8GB needed slightly more CPU voltage to be stable at 3200c14. Nothing else made any difference and apart from that I kept the same settings as 2 x 8GB. At 2 x 8GB 3333c14 was fine. Went from 1.2v to 1.26 on a Ryzen 1700 @ 3.7Ghz, your CPU differs being second generation for the actual voltages.
