Setting up Pi-hole
9 Jan 2019
I had a bit of faffing around when i transferred my old Odroid pihole over to a virtualized one on the HP microserver the other day but i think i have got it licked now.
This was on the latest ubuntu server, did some updates and it all seems happy now.
7 Feb 2004
North East
Finally got pihole set up as a ubuntu 18.4.2 LTS VM on my windows server after much trial and error.
I used followed this guide https://www.linuxincluded.com/install-pi-hole-on-ubuntu/
I used default options for everything, but have used quad9 as the DNS and added the below regex to my blacklist, which will apparantly stop youtube ads.
^(r[0-9]+(-{3}|.).+.googlevideo.com)$
r4---sn-vgqs7nez.googlevideo.com
Looking forward to testing over the next few days :)
Edit - first regex seems to block the youtube video you're trying to watch. Just the second regex seems to still let ads through (pixel 3 ads mainly so far).
15 Aug 2010
N. Ireland
Pihole is really something you setup once and never look back on. Have had mine up and running for nearly a year without much interaction apart from a couple of updates.
Need to setup VPN again that can utilise the ad-blocker on the go for mobile devices.
1 Dec 2010
England
Thanks for the link, installed Ubuntu Server 18.04.2 LTS on a N40L Microserver, setup pihole and added block lists from https://blocklist.site/
Is it possible to block specific url using pihole? e.g. reddit.com/adult or can you only block domains as a whole?
1 Dec 2010
England
I've configured the router so that all devices on the 192.168.1 subnet are given the IP of the Ubuntu server to use for DNS, but as the Ubuntu server sits with in this range it is also given it's own IP address to use as DNS.
7 Feb 2004
North East
I've tried to get Pihole running reliably a few times now, and each time i seem to have DNS trouble after a day or so :s
Any advice?
I've had a Hyper-V pihole ubuntu server running for a week stably now, and can connect to the admin panel fine, so I'm eliminating the setup/server stability as an issue and can only presume it's some sort of network issue.
Before I make the jump and change my router (talktalk huawei hg635) dns to the pihole ip address, has anyone got any advice or any extra steps I should take?
1 Dec 2010
England
Any advice?
What hardware are you running Pi-hole on?
19 Oct 2002
Bath
Any advice?
Unless you are running other services on the hyper-v it's vastly over powered, have a look at docker for pihole far lighter on resources than a full blown VM.
I run a docker pihole as a back up to my RPI1 with zero issues. Previously I ran a Ubuntu VM and pihole that would fall over quite often for no apparent reason. Headless with no GUI. Is the way forward for a host.
7 Feb 2004
North East
Can you describe the issue you're having?
It seems to run fine initially, but i hit internet connection issues and the chrome errors point to a DNS issue.
I've upgraded my server, so now running on a Coffee Lake i3 9100F with 16gb RAM and Win 10.
I have Win 10 and went the Hyper-V route as I couldn't manage to get my head around dockers on the windows application and just gave up. It's a headless server and running 24/7 anyway, but I'm open to dockers if it's the way to go. Not sure if it's the best way to do it, but my plan is to run a few hyper-v hosts; pihole, plex, CCTV etc.
Win 10 is running drivepool.
I'm not sure if things runs better with a VM or just on the OS itself (as most can just be a windows app), but thought i'd give it a go to separate things out and as a bit of an experiment. AFAIK what i'm trying to do should work.
19 Oct 2002
Bath
Give docker a go it's a steep learning curve but will do everything you want with much lower overheads, and to be honest once you have looked at it it's not that hard.
Currently running in my server native I have Plex, Lidarr, Radarr (Lidarr and Radarr don't like docker for some reason). In docker containers I have audio sonic, book sonic, lazy librarian, pihole, sonarr, portainer (for managing docker containers remotely) and watchtower (auto updates containers on the fly). And Heimdall (web interface for all container front ends).
Current hardware is Xeon E3 1260L 24gb or ram and 20TB storage with 128gb SSD for Windows and docker.
I prefer Plex native rather than containered as the CPU/GPU requirements are highest of any application I run because its shared with 8 people.
Don
19 May 2012
Spalding, Lincolnshire
How are your clients configured? Via DHCP or manually? Your pihole should be the primary dns, and the secondary left blank.
PiHole runs fine in a VM - I run it under ESXi at home, and under Hyper-V at work.
