Best X570 Motherboards
25 Jan 2006
Kent ,UK
ASUS STRIX B450-I Gaming ITX or Pay a bit more X470-I Gaming ITX ,
Both have the best Phases True 6 + 2 &
also got 1 x PWN CPU header / 2 x PWN fan headers ,
Lovely RGB lights, Good amount of USB ports,
Best ITX boards for phases on the Ryzen 450/470
Or go for the
Gigabyte B450-I AORUS PRO WIFI (Socket AM4) Mini-ITX Motherboard
4 + 2 phases
No ITX boards have the bios flash button, So you will need a CPU
The 3 ITX boards are the best Looking Also & all come with RGB headers & great fan control
11 Oct 2015
Thanx guys are Asus and Gigabyte one of the better motherboard manufacturers ?
Or go for the
4 + 2 phases
No ITX boards have the bios flash, So you will need a CPU
Would the Asus X470 be the best of the bunch and would serve me will for a few years with a ryzen 3700x?
At a total guess, I’d say about £2-250.
Yea ive still yet to see prices on the x570s but i have seen there is a Asus ROG Strix X570-I Gaming.
25 Jan 2006
Kent ,UK
Asus line I hear going to be a lot, it is Asus after all :)
ITX board easy £220 or up & Really you just be paying for few more phases
Asus still not got all the specs up on the X570 line, only basic info.
11 Oct 2015
Yea just read an article and seems to be state $100 increase which normally converts to £100 dont really be wanting to pay £250-£300 of the motherboard as well as £300 for the cpu and whatever memory i need
Also you state 450/470 itx boards dont have usb flash so does that mean i would need a amd cpu from older gen to flash to new ryzen ?
25 Jan 2006
Kent ,UK
Yes you will need a 1000 Series or 2000 Series Ryzen CPU to flash the bios
also a graphics card - Evga Gtx 1070 SC ?
if not then a 2200g or 2400g or a Athlon CPU with built in VEGA graphics will be needed
Can always Give OCUK a call & ask if they could flash the Motherboard befor purchase
ask a friend or shop
ask AMD for a upgrade kit to borrow
25 Jan 2006
Kent ,UK
Just noticed, Gigabyte are Based in the UK & Europe, Also got how own REP on Here.
are good, Don't know about RMA with Asus Europe,US
If you can Wait, tell Reviews/ Prices & Pre-orders on the 7th...then maybe wait for x570
always resale the CPU after bios upgrade get your money back.
