- 7 Aug 2004
I'm really concerned about the potential removal of force touch on the newer models. I use it daily to select, highlight and edit text with a single digit using various pressure levels.
I fear if they remove it they're going to totally shaft those of use that actually use our smartphones as productivity mobile computing devices and knock us back a few years compared to laptops and desktops, which is weird seeing as so many of the iOS13 updates seem aimed as making iOS a much more capable overall computing platform
If they ditch force touch after ditching mag safe it will feel like they're dead set on completely tossing out the window some of the best innovations Apple ever made.
Isn't it becoming long press though? I just tried out what you said you with txt....iv never used it before or known what it is.....it's confusing and I messed up selecting a txt sample......and iv never used it before, likely why their removing it 99% are unaware
