Wall Mounted Post Box
4 Dec 2002
Bourne, Lincs
Having a new front door fitted next week that does not have a letter slot, so want to get a wall mounted one, other than just picking one that looks ok on Amazon or something anyone have any specific recommendationos?
Cheers
Kimbie
We have the Brabantia wall mounted post box with a newspaper holder underneath. It works well and never had any issues with it, this came with the house when we bought it. When I come to replacing the door I will get one with a letter box as I find it to be a bit of a pain and the only benefit I can see from it is maybe from a security point of view. Also, it does leave your post open to theft as you can easily remove an A4 envelope from it without opening the door of the post box.
I have just had a quick look at whats out there and I would maybe go for something like this which has a hatch if I was to replace it before the door, because then you would not be able to pull the post out of the opening like you can on mine and most of the ones I can see on Amazon.
Thanks for the replies, the one roccles mentioned looks good, though its pretty deep so need to see how it would look
But half the time Amazon puts parcels over hte gate if not in or to neighbour and most mail get is either junk, or tesco vouchers, all the important stuff like bank, utilities is all online now
We’ve got this one: https://www.safe.co.uk/products/brabantia-b110-white-post-box.html
No issues with it, we opted for a door with no letterbox because it’s weather facing and I didn’t want a nice new storm force door with a huge hole carved it it :)
Big enough for most amazon parcels to drop in (your average book / dvd/ small object)
