- 3 Jul 2019
Wouldn't in theory of it stutters it will just drop the fps lower.. I'll try! So chances are it's not the RyzenYou need to test, put it on and see how you get on
Tried it it still did it...Wouldn't in theory of it stutters it will just drop the fps lower.. I'll try! So chances are it's not the Ryzen
Haven't had a chance to run any test.. but fps around 95 plus on ultra, then when it stutters it goes down in the 30s just for a split second.. but enough to be annoying.. my older PC didn't do those things.. only game I normally play is pubg! Resolution is 1080p 60hz.. just did a fresh install to try again.. used cccleaner to remove Xbox apps as I seen in another post that could be an issueToo little info for any diagnosis.
Parts should work fine without stutter.
What resolution is the screen? 4K, 1440p, 1080p
Have you run any CPU / GPU benchmarks to make sure each is performing as expected?
Do you have the same stutter in all games? Examples of games with the issue?
What settings are you using in games, does it still stutter at low / medium ?
What FPS are reported when gaming?
What temperature are the CPU and GPU reporting under load?
Etc.
Hello all
PS: Also on frames higher than 120 fps there is a loud coil whine (seems common, especially for that model), and with an aggressive fan curve it's a jet engine.
PS: DDU done in safe mode before inserting the card, with auto update stopped, no concerns there.
Edit: boy did I pick the right time to make my first post here...
do you get a lot
do you get a lot of this ? I thought the coil whine is a defect is just this card or others a well, also are the fans noisy ? as I was looking at this card cheers
Thanks for the infoPulse was always recommended as it was way cheaper than the PowerColor Red Dragon.
Now that they are the same price I'd choose the triple fan PowerColor over the dual fan Pulse if his case is big enough, also it has a higher boost clock.
They have the wrong boost speed on the PowerColor webpage info.. it says 1478MHz when its actually 1590MHz.
Heres my Red Dragon in GPUZ showing defaults.
Red Dragon is a long card though (around 330mm length).
Here is a pic of it next to my Sapphire Nitro+ RX 480.
The update before last also introduced stuttering. They have quickly patched this however. If you have not been on it for a few days you will have an update that fixes the stutteringThere are specific issues with PubG stutter on a broad mix of hardware. I'd start by googling PubG stutter and look for some suggested fixes.
do you get a lot
Got a 56 recently but having nothing but issues with games on it like gta 5 stutter when going fast, no man sky loading screen takes ages and shows 7fps and after when u turn it stutters like pauses and catches up and gta 4 wont even go past loading screen after clicking start game it just black screens with some audio playing and flashes 2 different shades of black screen. Wondering if its the latest drivers if so is there a magic driver everyone is using for this card (the pulse).
