So what’s happening on Sunday?
When you break information/leaks like that, it's customary to start withAMD have been sand bagging and it's really Navi 20 at $450 and delivers 2080Ti performance
Roast potatoes, chicken, veg, lots of gravySo what’s happening on Sunday?
Is it Ryzen CPU launch on Sunday also ??
Hexus are reporting rumours of AMD cutting Navi prices.
- RX 5700 XT 50th Anniversary: was $499, NOW $449
- RX 5700 XT: was $449, NOW $399
- RX 5700: was $379, NOW $349
Personally thingk you are wrong just by the generally sweeping statement of PC gaming, dont bite my head off first read on. Think of all the games out there at the moment bar the RTX ones and to play them a good 1080p card will suffice. A card such as a RX580 or GTX 1660/ti can give you an excellent 1080p experience. A 980 or 980ti still can. So PC gaming is becoming too expensive - why ? What do you need to buy so you can play a game. Nothing. There hasnt been a game you need to buy a graphics card for in order to play it for a long long time.
If you compare console gaming against a PC playing 1080p games its not that much more expensive. The new PC hardware is expensive but then you dont really need it. Do you ?
Oh no I get your point too, you put it well.
To play modern games on a PC, I mean modern demanding games, not CSGO or the like
Windows OS
Mouse
Keyboard
CPU
RAM
MOBO
Case
GPU
PSU
SSD/HD
I'll use ball park figures, nothing looked up, just a "rough" estimate
Windows OS - £25
Mouse - £10
Keyboard - £10
CPU - Quad cores are starting to show their age but we'll run with a quadcore from AMD - 1400CPU - £130
RAM - 8gig £40
MOBO - some B450 board - perhaps £85
Case - £25
GPU - RX560 - about £125
PSU - £40
SSD/HD - for a 256 to fit games and OS - £30
That's over £500 easy. Yes you could go for a APU from AMD but you'd need faster RAM and APU's can just about play 1080p MODERN GAMES remember, at low settings. Console you can get for less than £500 now.
I remember building a HIGH END setup, at the time, with a 4870 GPU and a q9550 core2quad, for around 650. Even with inflation, you can't really build a high end pc now for less than 800-1000 to be able to comfortably play at 1080p modern games at medium settings.
Mid-range GPUs at high prices. The fact that these cards were supposedly named 690/680, they should be priced in line with the 590/580.
Both AMD and Nvidia are taking the **** with pricing.
CPU can be justified because AMD are doing what Intel can't/won't, GPU... Another gen I'm sitting out personally
Tell you what would be good from AMD
if they do some sort of discount voucher if you buy an X570 board, a Ryzen 3XXX and 5700/5700XT on Sunday.
That would be absolutely glorious for people like me .
@Gibbo
Make them see the light![]()
