Sorry, I meant the max supported RAM frequency for the motherboardThe memory controller is on the CPU.
Hi, hopefully someone can help me find something out.
I've been trying to find a 300/400 series motherboardwith a memory controllerthat can handle DDR4 3600 Mhz RAM or higher, ideally for £100 or less.
If so, what is the name / model number please?
Otherwise, I think I will stick with 3400Mhz RAM.
I've been thinking x570 would be a good option if getting 4000Mhz or higher RAM, as older AM4 motherboards can't support it.
Just as a slight warning, I just checked the CPU support list for the asrock b450 Pro 4, and it's got the 3800x but, notably, not the 3900x. Might be an oversight, but might also be that not all the CPUs actually work on all the boards even if they have VRMs that should be able to cope.
There's a review here that claims to be running at DDR4 3600 mhz here, on an ASRock board:
https://www.tomshardware.com/review...g-itx-ac-overclocking-motherboard,5824-2.html
What do you guys think? Is this legit? Officially, the board only supports upto DDR4 3466+.
I did hear that memory clocks can be higher on dual RAM slot boards.
Ofc the VRMs are overkill, for some ridiculous reason it's what we obsess over on motherboards. Hell, buildzoid will spend HOURS talking about the VRMs on a board. And how important they are.i would be very suprised if the top x370 and x470 did not suport the 3950x
i get that the vrm was not allways the best be we are all just guessing how much more the 3900x and 3950x will stress them. My own personal view i think the vrm on x570 is over kill and the better x370/x470 and b450 will be perfect platforms for amd best cpu
if amd was majorly concerned on x370/x470 not being able to handle the extra cores on the new cpu they would have made a whole new socket am4+ or something and compltly locked off the older motherboards for ryzen 9 and make the 3900/3950 as requiring x570
Truth of the matter is. Unless you are overclocking to the moon on LN2 then they just aren't. Certainly not to the level that they have been put into X570. I mean it's very likely ryzen 3000 will overclock a few hundred Hz at best. So the VRMS are of no concern.
But while people keep obsessing over them and buildzoid and gamers nexus keep going on about them (because they do LN2 overclocking) then we will pay for stuff we don't need.
Asrock has not yet updated 3900X support for any of their boards. None of their X570 boards have 3900X on the supported CPU list either.
Really? How can you have a brand new X570 board not support new CPUs one day before launch?
Is it though? My 5960X gets 5400 single core at 4.5ghz and that launched in 2014. Also the 4.35ghz suggests to me that's a typical clock speed at load.Ryzen 3900x
https://browser.geekbench.com/v4/cpu/13776562
Single score 5818 only at 4.35 ghz
Multi score 47798
That's impressive.
The more results I see the more I doubt Zen 2 despite what we all would like to see and are hoping for.
No, but the 65W 3700X for £350 is. Scored 5700 at 4.4GHz. We will see more in the days to come.
Wait the £220 R5 3600 scored about the same 5700. Now, that is impressive.
