You have a Vega 64 listed with the new Navi cards.
ROGUE VEGA 64 STILL IN THERE!!!!![]()
Ahh shouldn't of bought the Vega
Radeon Software Adrenalin 2019 Edition 19.7.1 Highlights
Support For
- AMD Radeon™ RX 5700 Series Graphics
- AMD Radeon Image Sharpening(1)
- New feature available in Radeon Settings that can be enabled for DirectX®9, DirectX®11 and Vulkan® games on AMD Radeon RX 5700 Series Graphics. Provides contrast-adaptive sharpening combined with optional GPU upscaling that helps draw out detail and provide crisp-looking visuals.
- AMD Radeon Anti-Lag(2)
- New feature available in Radeon Settings that can be enabled for DirectX®9 and DirectX®11 games that improves input-to-display response time with up to 31% reduction in lag.RS-295
- AMD Link(3)
- Now supports auto-discovery mode and one-tap connection, allowing you to easily connect your Radeon PC and AMD Link App.
- Now supports connections to Apple TV and Android TV with a new simplified TV interface.
- AMD Radeon Chill(4)
- Now supports display-aware tuning which sets frame-rate caps to match your monitors refresh rate providing up to 2.5x more power savings than before.RS-294Display-aware tuning works with fixed-refresh monitors or with variable-refresh Radeon FreeSync™-capable displays.
- AMD Radeon WattMan(5)
- New power gauge readout available in Performance Metrics Overlay and Radeon WattMan.
- Auto Tuning features now provide a summary readout of tuning changes.
- Settings Snapshot(6)
- New feature available in Radeon Settings that allows you to create, save and load your custom settings and configurations for Radeon Settings.
- Automatic Low Latency Mode(7)
- Allows supported graphics products to communicate with your connected TV and enter low-latency (gaming) mode automatically.
Surpriiiiiiiiiiiiiiiiiise!!![]()
with Asus RMA I wont be buying asus again. the Tax is just to Pee you off more.
I'm not bothered. I sold the games that came with it so it cost £275 for the Nitro. So £60 cheaper than the 5700 and it's not that much slower. I couldn't have a blower card anyway as I have the carbide 240 and it isn't the best for cooling.Happy i got this now
Getting The vega 56 thank god saved me £100 over the 5700, That £100 saved will go towards the rest of my new build. The vega 56 still keeps games above 60fps at 1440 anyway.
I can not see them dropping the vega 56 at all now as its still cheaper than the 5700 as its priced now, The 5700 are blower cards as well as when the custom cooler versions come out they prob be even higher priced which could be £50 more so getting the vega 56 could be a potential £150 saving when they come out.
not very often i get a good deal, lol
of to see what i can build
