Yeah unfortunately another round of reviews with raising voltages and power limits -_-
Some like Guru3d said that "we do not like Wattman" so using MSI AB (which admits doesn't support properly Navi yet) and cracks up the power and heat.
Others are not further behind, as they are not bothered with Wattman either.
Guru3D also V64 review was a joke also. He raised the floor voltage to 1250mv. So the card was trying to push 1250mv even on low speeds resulting to overheating and heavy throttling.
As soon as I have my Anniversary edition later this week (hopefully), going to go through series of tests and settings and I will post detailed results
Shame I am not a reviewer getting that free gear to test, and return afterwards. I would do much better job that most, even on Nvidia GPUs. Which all of them are on "move the sliders" in MSI AB, and not fine tune the cards using the curves. (which resulted pulling 2190 from my GTX1080 Armor, and similar high clocks on the 1080Ti).
