- 18 May 2010
- London
Whats Cyberpunk?
Cyberpunk 2077
Whats Cyberpunk?
3900x vs 4790K (I know a lot want to see this). 10% uplift on average. Kinda sad actually. 10% in 5 years. And thats ignoring that large overclock you can typically get on a 4790K. Im willing to bet they are the same FPS if the 4790 is at 4.6-4.8Ghz
Give the 3900x some games in two to three years though and I suspect the 4790K would fall off a cliff in comparison at same settings (at least at 1080/1440. I would say that at least my 4790K has never had great frame timings and compared to a few Ryzen systems I have used previous it at least didn't feel as smooth when gaming.
I am expecting my 3700x to come next mon/tuesWe likely won't get them this week let alone today I think
***Another Retailer*** aren’t getting stock till next week. I know they don’t specialise in PC components but with their buying power and supply network it does give you an idea of what a shambles this 7/7 launch is from AMD.We likely won't get them this week let alone today I think
I’m still hoping OC’s pull off some magic though.
And this video makes it look like the all core boost of the 3800x is on average 100MHz higher than the 3700x up too 4.4GHz.
The 1% lows look much better on the 3800x tho. Up to double in what looks like to be the Division 2
So my take from that video is the 3700x and the 3800x will give you on average similar highs and average frames, but the 3800x will give you much better minimums.
From Reddit about the concerns that the PBO not boosting properly
So it sounds like its not a bios problem, but working as intended![]()
I've decided that the thermals on this 3900X makes no sense whatsoever.
It idles high, like 30-50*c, usually hovering in the low 40's.
If i manually set the voltage down from what appears to be a fairly consistent (but still changing) 1.4-1.5v, down to 1.2v, it idles 3-5*c lower, and Primes up-to 83*c after a few seconds.
If i leave it as is, and let it do what it wants, it idles as above, but primes around 65-69, with the occasional micro-spike to 77*c.
So use less voltage, create more heat!?
Got my 3600 installed in my Gaming K7 X370 board and now my nvme drive isn't showing up, running latest F40 bios
Is it connected through the chipset?
Not 100% sure, guess so since it's only nvme slot on board ?
I’m not sure on that board but I would think it’s direct to the CPU. Check your BIOS options.
These are my thoughts exactly. The next 1-2 years where games start making use of threads more and more, I think the old Intel parts will drop off quickly in performance.
