Permabanned
- 15 May 2006
- London
What games you play?I will get R15 then and try again.
As long as my cpu is best in games, I am ok
Your right. My 9700K is crap in cine bench. Glad I only play games![]()
When you have time could you elaborate on this.Motherboard fan (Aorus Ultra) has been mostly quiet
Going from;
CPU: i5 4670k @ 4.5ghz (served me faithfully since 2013!)
Mobo: Asus Z87-A (another 2013 survivor.)
Cooler: Arctic Freezer 13
GPU: Sapphire Vega 56 Air Boost @ 1650/950 MHz (1050/1050 mV) (Recent upgrade from GTX 970)
RAM: 16 GiB DDR3 RAM @ 1866mhz
OS & Games SSD: Samsung 860 EVO 256gb
HDD: Various assorted HDDs from 750gb to 3TB
Case: Corsair Carbide 200R (again a 2013 survivor!)
PSU: Corsair TX-M 650 80+ Gold
To; (reused parts in italics)
CPU: Ryzen 3600
Mobo: MSI B450M Mortar
Cooler: Stock, until I decide whether I want to go AIO or air
RAM: 16GiB DDR4 G-Skill Hyper-X 3200mhz
OS SSD: Samsung 960 EVO m.2 NVMe 500gb
HDD: Not sure what will fit in the new case yet!
Case: NZXT H400i (Red of course!)
Parts have arrived today, just another 3 hours work left to go and then it's playtime![]()
4400Mhz 1.375v with better mem timing.14-14-14-35 3666Mhz a lot more tuning to do. Should be able to get memory tighter.
Managed to get my temps down a lot 4.3 1.25vcore idle 36c 64 load. Will be my day to day setting now.
Is it inaudible when idle and if so what tasks were you doing that made its presence known?
*There are BIOS updates coming soon for the fan - Clicky - semi-passive mode soon.
What did you upgrade from @Boomstick777 ?
Will do some testing later amazed how stable it is at 1.25v took me by surprise been playing games and doing benchmarks no lock up doesnt miss a beat. 4.4 is my limit at 1.35v. 4.5 takes 1.45v too high for me.Intel Burn Test stable? If so that is amazing.
Is it really worth loosing 300 in ST but gaining what? 100 in MT?![]()
Ryzen 3600
Asus TUF X570
3000mhz DDR3 RAM C16
SSD (OS) and HDD straight from old PC (Sandybridge) loaded up fine, did not update bios or chipset (yet)
Using stock cooler at the moment and CPU temp up to 96 degrees in Games![]()
