** The AMD Navi Thread **
Uzu
Uzu
28 Mar 2018
Yorkshire
The max OC isn't really doable on air.
But i’ll see how far my memory will go and retest the max oc with that mem OC as well as what ill actually run but I doubt it’ll go much over 900 on wattman.
Im aiming for the best underclock that 35% fan speed will get me as its fairly quiet.
At the moment I'm getting ~1960Mhz and I've barely touched the memory thats my next goal.
Caporegime
18 Sep 2009
Dormanstown.
I’d image 2100Mhz fairly easily as I'm touching it on air.
The max Wattman allows for the slider is 2150Mhz.
I have a powercolor and it does have a sticker on one of the screws.
What is with all these companies sticking warranty stickers on.
It's bloody shocking
I just went to take the cooler off my sapphire limited edition Vega 64 to see a sticker too
Uzu
Uzu
28 Mar 2018
Yorkshire
Caporegime
18 Sep 2009
Dormanstown.
Its just default with the demo turned off so 1440p.
I'm done with OCing for today found my sweetspot with noise/thermals with fans at 35%
So for my card
Stock - https://www.3dmark.com/3dm/37492879?
Everyday UV/OC - https://www.3dmark.com/3dm/37492765?
Max OC - https://www.3dmark.com/3dm/37493404?
Thanks for all those.
So a maximum gain of 900 points.
What's the percentage wise?
~10%.
I believe that a 5700XT max OC is probably nigh on with a stock 2070 Super then, or to a point where you'd fail to tell the difference overall.
EDIT : I've taken delivery of my Morpheus Cooler now. It's not quite what I ordered, but I think it fits a 5700XT.
If I take my morpheus purchase in isolation I could justify probably the 5700XT.
OC'ed I imagine the 2070S is ~10% faster than the 5700XT but it's also 20% more expensive.
OcUK Staff
17 Oct 2002
OcUK HQ
Right cranked it up.... let’s see what I get. I’m loving this card at moment
The 5700 XT overclocked is literally reference 1080ti performance pretty much for under £400 and that on like day 1. As drivers mature and the architecture is taken advantage of its only going to get faster. For £379 they are epic value!
