Do you know what kind of core speed you hope to achieve on water?
I’d image 2100Mhz fairly easily as I'm touching it on air.
The max Wattman allows for the slider is 2150Mhz.
I have a powercolor and it does have a sticker on one of the screws.
RazerbladeWhat is with all these companies sticking warranty stickers on.
It's bloody shocking
I just went to take the cooler off my sapphire limited edition Vega 64 to see a sticker too
Razerblade
If you move these things with good enough care they never know.
I legit just maxed every slider, memory was at 900.
Looks like 910 memory is where i hit the wall, ill try another run and see if 10 on mem makes a difference.
Haven't touched anything on the CPU side yet.What settings you using for your 3900X? Just auto?
My next plan is to see what all core I can get.
Max OC I can get by the looks - https://www.3dmark.com/3dm/37493206?
So I recon that should be doable on water if your card is similar to mine.
Its just default with the demo turned off so 1440p.What resolution is your timespy at? You're 800 points faster than a review I just saw.
I'm done with OCing for today found my sweetspot with noise/thermals with fans at 35%
So for my card
Stock - https://www.3dmark.com/3dm/37492879?
Everyday UV/OC - https://www.3dmark.com/3dm/37492765?
Max OC - https://www.3dmark.com/3dm/37493404?
Right cranked it up.... let’s see what I get. I’m loving this card at moment
The 5700 XT overclocked is literally reference 1080ti performance pretty much for under £400 and that on like day 1. As drivers mature and the architecture is taken advantage of its only going to get faster. For £379 they are epic value!
