Not sure what has changed but using just one 2080ti on BFV on ultra with RTX at 4k I get a pretty solid 60fps. Once in a while it dips below to 50fps but not often
#MeToo.
So, seems things are much clearer now...
As someone who’s building an entirely new build, and so does need to buy a current gen GPU:-
The two Navi cards coming out soon do not compete at the high end.
2080 Ti is still poor value for money.
The 2070 Super appears to be the best value for money.
The 2080 Super is the move if you’re going for high end but unwilling to fork out over a grand for a GPU...
Right?
I’m pretty set on the 2080 Super, but acutely aware that I’m both thick and generally ill informed, so feel free to correct me!
It may when highly clocked equal the 2080ti. But this i assume would be 2x8pin 3 fan versions it has a max thermal of 81c.
Possible but highly unlikely, IMO. Nvidia would rather you bought the more expensive card.
Do we have an ETA on the 2080 Super?
Gosh I nearly bought a Ryzen 3800x which I really didn't need. Need to not be tempted by the 2080 super either! I want to wait it out for the 3000 series.
26th? I am going to wait and see what price first though and either Gigabyte Aorus or Zotac AMP. I said my goodbyes when the 1080 broke so am commited to no gpu until August 3rd. I will probably install it that weekend IF there is stock and no gouging.![]()
Dice patched the hell out of the raytracing on BFV a while back. Much better performance since. Shadow of the Tomb Raider shadows were never too intensive. Metro Exodus lighting was the toughest after BFV got patched and is still doable
Even then the RT is still low quality (even at ultra) Turing just doesn't have the hardware for a high detailed Ray tracer. The Cyberpunk demo at E3 ran on a titan RTX at 1080p30 to get teh quality they showed. And there is only so much optimising you can do with Ray tracing to reduce teh computational load before you start greatly compromising quality.
2080 Super is £669 for FE and basic models, expect an ROG Strix to be like £750-£800
I dunno if it is the same one as used in BF V but the denoiser used in Quake 2 RTX does quite an impressive job of mimicking a far higher ray count than is possible - Turing might struggle but I think next generation hardware will do fine.
Also quake RTX isn't actually performing ray tracing, its using the more expensive Path tracing, which is more physically correct. But it can only do it due to how simple the scenes and geometry are.
