This is beyond frustrating now...remounted 3 times and still getting high 80s when I run prime95![]()
I don't think that's the case with desktop AMD Ryzen as the chips are pretty much clocked to the limits of the silicon, the CPU hasn't failed it's just not stable at rated clocks. I would try disabling turbo boost to see if it fixes it.
Just got my system built out, the ram defaulted to a little over 2ghz and the cpu clocks are jumping around very quickly. Even caught a glimpse of 2 cores at 4615.6 whilst idling, nothing was demanding that high a clockspeed but I'm not complaining.
Going to install drivers etc and config the memory
I've got absolutely no clue about ryzen master myself, I made the changes in the biosI'm new to this 'Ryzen Master', I want to lower the voltages a bit as it's hitting 1.476 regularly based upon stock. What option/offset can be safely tweaked?
I'm using ryzen just to monitor as it seems to be the only one that gives accurate temp and clock readings, I didn't enable PBO, is it on by default?I’m on Ryzen 5 3600 and I too have noted high temps (90+) with the default settings. I will add further cooling and report back. Are you using Ryzen master to monitor temps ? Do you have PBO enabled ?
Most of the problems I'm seeing are BIOS related.
Hopefully Asus get their s*** together soon and fix all the bugs.
Early adaptors being the beta testers once again.
How are people finding the mobo fans with x570? Loud whilst gaming?
Anything in particular you had to do to get these speeds? My kit won't boot at 3400 MT/s or 3466 MT/s with "safe" timings at 1.35 V. In fact it just gets stuck trying to POST. No error codes but nothing happens for a solid 3 minutes. Have to forcefully power cycle it.Had a bit more time before this morning meetings to mess about with RAM, still not excellent, but getting there. @Plec
Will hopefully have more time this afternoon, might even fetch the system home to tinker with tonight if I am still feeling there's more to be had.
