I suppose. I still managed a 3.5% bump in x265 just by tightening the timings at 3200 MT/s though so there's definitely something to gain!Don't worry, I'm even further down the pecking order for BIOS updates than you
One the plus side, at least the newer 3rd series CPU's are less affected by memory speeds than the 1st and 2nd gen![]()
Saw this user on Reddit with basically the same problem on another ASRock X370 motherboard with ComboPI 1.0.0.3:
https://www.reddit.com/r/ASRock/comments/cbm4aw/asrock_x370_fatality_gaming_pro_and_ryzen_3900x/
