- 21 Sep 2018
Thanks for the suggestions! I gave the windows balanced plan a try and the temps dropped 10-20c and vcore now fluctuates between 0.98 and 1.465 in HWINFO and 0.862-1.352 in cpuz. Cinebench score went up 200 points too. All the advice I'd seen online was to use the Ryzen Balanced Plan so I set that as soon as I'd installed the drivers.. it seems that wasn't good advice.
HWINFO seems to show higher vcores than cpuz but that may be down to what AMD_Robert said on reddit about current tools polling the cpu.
Cool. You can also play with Windows plain Balance and 25% minimum processor state. That's what i use for Zen 1 and 1+.
@Dragon there is the latest beta from HWINFO64 but it too does not show cpu temp. Just Tdie but the rest seem legit.
https://imgur.com/hhhK05f
