- 20 Oct 2002
- London
i'm hearing mixed reports about the 3900 on the 450 tomahawk. Anyone confident to tell me it'll work fine (at stock). Got all the bits here and really hoping to build tomorrow
At 4k not a lot of difference. Obviously I'd go Ryzen for the upgrade path but if you're well off go Intel and upgrade the CPU and motherboard when they release something faster.
i'm hearing mixed reports about the 3900 on the 450 tomahawk. Anyone confident to tell me it'll work fine (at stock). Got all the bits here and really hoping to build tomorrow![]()
I’m not even getting it on one core
2500k here as well.And don’t be a noob like me and fail to consider psu connections have moved on (8 + 4 pin cpu power needed on my board). I ended up rushing out for a new PSU pushing the budget up
One of the issues buying AMD stuff early I think (going on history) but issues should be sorted soon. It's one of the reasons I'd prefer to go 3950X - all the platform issues will be sorted by thenThis ryzen kills my patience. amd as always with cpu, not prepared for sales. Date is more important than happy customer
@Journey might be able to help. Personally with 3900x and looking for MSI would go x570 Carbon - but similar price to x570 Gigabyte Gaming X
2500k here as well.
I never ever concidered that and just checked my Corsair xt850w to find it only has one 8 pin conector.. More money !! oh well morning shoping on oc . Just need to look at power suplly revues first..
must admit i'm tempted to get a 570 and return the 450. Won't get delivery until next week though i suppose. If it saves me the headaches of trying and possibly failing to get things going on the tomahawk, plus i'm getting a more advanced chipset, i think i can stomach the price increase .... just![]()
I think you'll find that you can get away with just connecting a 8pin connector for the cpu and ignoring the 4pin (which is what I've done with my x470 motherboard). Buildzoid in a video mentioned that the extra 4pin is not really necessary.2500k here as well.
Should be able to use it. It will just extend your sub by 3 months
Can’t go wrong with a Superflower. Absolutely love em.To be honest i would rather not even though i did see Buildzoids comments! And considering my psu is 8 years old and not modular may be a change is not such a bad thing.
One main advantage of newer chipsets and this is said by all vendors is that they get all the attention for Bios updates . Get it running perfectly on newer systems then work to the older ones . AC is a damn good board with 6 and 8 cores, fair play to them .
X570 is easier for someone that wants to slap I. 3600hz ram and do nothing - more plug and play
Wondering if MSI b450 will rise higher ..
It does seam Superflower and Seasonic are the flavours of the month at the moment?Can’t go wrong with a Superflower. Absolutely love em.
....done - return issued for b450 tomahawk. A shame i never got to play with her
now, which x570 to get....don't want to spend any more than 300 absolute max but preferably less of course. Will favour more usb3 ports over stuff like wifi which isn't needed. MSI again?
