Dunno ppl mine was boosting to 4.4 on the first boot; full auto ,with only xmp profile on.
. Settled for a manual overclock instead so still happy thoughAndy could you possibly let me know what you score with Cinebench R15 please?
)?Looks like your memory and infinity fabric clocks aren't 1:1 (Under Memory Control, coupled mode should be on) so there will be a latency penalty. You either need to drop the fabric clock to 1600 or increase your memory speed to 3600MHz to match.Well after 2 days with this new build I am pretty impressed. I was half expecting some teething issues with it being a new chip and mobo along with immature bios etc but upto now I haven't come across any issues. Mobo bios is left to auto everything except memory profile (had to select xmp profile 1 to get it to run at default spec). Even seems to be boosting correctly as per screeny below.
Reports from reddit of corrupted M2 drives due to ryzen whea errors, better check up on that
Just to confirm, Intel 660p here, did the same checks and has the same problems on an Asus x570 Crosshair Hero connected directly to the cpu's pci-e. Whea events all triggered by Intel's NVME controller in this case. 87 files required "DISM /Online /Cleanup-Image /RestoreHealth" to fix, so looks like it was caught just in time.
This bug is catastrophic and needs to be fixed asap, otherwise these systems with NVME drives may as well be considered unusable.
level 2
Geahad
3 points·2 hours ago·edited 1 hour ago
OK... This is now very concerning indeed.
Data corruption, and especially OS file corruption in NO JOKE.
I'm somehow more and more convinced it's a bios bug. But perhaps it can be circumvented via drivers for individual devices.
