Go to 7:51Anybody running 1440p with a reference card? If so what is noise like?
Go to 7:51
I'm running 1440p with the Refresh Rate at 100hz...the fan noise is nowhere near as bad as made out. If you have sound on (which you will) while playing anything at a decent volume then you won't hear it.
Cheers, i keep it in mind, i had the vega reference which when i went to 1440p was just unbearable.
Welp I can't play apex with 3rd gen ryzen and a navi, GPU drivers crash everytime I start the game.
10/10 not salty at all![]()
Are you overclocked on gpu or cpu?Welp I can't play apex with 3rd gen ryzen and a navi, GPU drivers crash everytime I start the game.
Go to 7:51
This is why I bought a 2080 after 20 years of loyalty to them. Amd always find a way to screw their gpus up, even when they have the right ingredients they serve the meal on a plate made from 7 dead squirrels, and dress like businessmen at a kids partyAMD should have gone with a twin fan reference model, As we've seen with Nvidia's board partners they're more than happy to make their own blower cards for the small percentage of people that actually want a blower card & AMD sticking to the blower design reference card means their sales won't be what they could have been, It's as if anything beyond developing the chip & putting everything on the pcb is a mystery to them, They screwed the Radeon VII up by insisting it didn't go over being 2 slots thick which resulted in there not being enough heatsink to cool it quietly & now they revert back to blowers which undoubtedly hindered release sales, AMD always finds a way to screw something up.![]()
Thanks for following up@Phate unfortunately got reply by EK today. I was told that there are no plans to make Aluminium block for the 5700XT.
However asked them if the generic Pascal block is compatible, because the layout is the same, with exact the same positioning.
I'll just get the normal block already posted then! It will match my CPU block anyway!
There will be a special edition water block launching soon. It will be a bit more expensive, but will also feature the special design.
