here ya go - the crux of it was that der8auer couldn't get the cpu to maintain or even reach it's stated boost speed.
seems so, at least at the moment.I see, ta.
Its almost like broadband with its "upto" speeds.
Really interesting that the dual-die design of the R9 3900X/3950X is consistently slightly faster than the single-die design of the R5 3600(X) and R7 3700X/3800X. I wonder if that is a result of the gimped memory write of the single-die designs? If it is, it's a justification for the decision I suppose: halving the bandwidth only affects performance in typical tasks by a tiny margin (a few % at most). Or maybe it's just the larger L3 cache per core?
3600X has same cache configuration as 3900XOr maybe it's just the larger L3 cache per core?
No it has half the L3 Cache. 32 vs 64MB3600X has same cache configuration as 3900X
Same amount of cache per core. 3 cores share 16MB of L3No it has half the L3 Cache. 32 vs 64MB
I run the 8 Pack 3200CL14 at stock.. which is 14-14-14-31-1T with 1.360v/1.1v Soc on 2700X 4.2Ghz All Core on an X470 MSI Gaming Pro Carbon AC.
No issues at all..
My cheap Taichi has been despatched
just waiting on my 3800x to get dispatched so i can build.Yep, thats why I wrote 3600X and 3900X have same cahce config. The upcoming 3950X will be similar to 3700X.If the cores can only use the cache on their own CCX then 3 cores sharing 16MB vs 4 cores sharing 16MB = approx. 33% more cache per core for the 3900x. Not to mention some other variables at play here.
point is you buy 4133 kit to run 3600 with super tight timings ?? If i got more money to burn i wuld be on 4500mhz kit to run it at 3600 cl13 or something.
Have You missed part where I upgraded from Binned 3733 mem kit to binned 4133 8pack ones ?? I highly dubt that Zen2 8pack mem kits will be running super tight timings 3633 at 1.45 - 1.5 volts xmp profile.binning of B-Die ram kits for low latency CL/1T don't work that way, it never has.
best advice to save money and time, just buy the 8 pack kits.
if money and time unlimited - buy some 3600 C16 or C17 kits, non-RGB and bin those but it is a slippery slope. The peeps binning 100+ kits each have an approx 10% hit rate for good CL bins.
I am kinda happy this is now a 'thing' because it means that companies will stop trying to throw crap 4200+ C19 kits down our throats and get us some proper ram.
