Lol I would have bought it at the price you said.No, I found that vat out after basket myself . just ordered it myself![]()
So now im on the fence, have to spend another £160 on water block and backplate(But that's the same with whatever card I go with), would be nice if AMD actually stated if its binned or just tweaked standard gpu!why dont they do this at default ? thanks for the info.
Hello,
I bought two 5700, but couldn't make them both work in benchmarks and games. Do I miss something, or it is too early for that ?
Thanks!
I haven't had AMD GPU since R9 290 and that is why I am thinking that maybe I am missing something ?Yes, but no luck at all. Nothing, nothing and again nothing![]()
That's the thing , you think great price, then at the end it Slaps you with the VAT...still a good price for a special gold sample & I say around 10% faster the a 2070 super
5700XT is better performance than a 2070 super, Yes
cross fire not enabled
In a comical turn of events, while NVIDIA restored NVLink SLI support for its RTX 2070 Super graphics card on virtue of being based on the "TU104" silicon, AMD did the opposite with "Navi." The Radeon RX 5700 XT and RX 5700 lack support for AMD CrossFire. If you put two of these cards on, say, a swanky X570 motherboard that splits PCIe gen 4.0 to two x8 slots with bandwidths comparable to PCIe gen 3.0 x16; you won't see an option to enable CrossFire. AMD, responding to our question on CrossFire compatibility clarified that AMD dropped CrossFire support for "Navi" in favor of DirectX 12 and Vulkan "explicit" multi-GPU mode. The older "implicit" multi-GPU mode - CrossFire - used by DirectX 11, DirectX 9, and OpenGL games is not supported. The AMD statement follows.
My 5700XT is running around 2GHZ on the stock cooler at 1125mv.
I'm going to stick the Morpheus II on it tonight (I had a nightmare rebuild)
What is it I need to do about the soft play tables and then what software am I using to get as much as I can out of it?
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000]
