AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
5 May 2017
Just out a curiously can somebody with a 3900x play the 8k60 fps youtube (without hardware accelerate) smoothly on chrome. (only if you have high enough internet connection.
I know the 1950x was struggling.
25 Jun 2013
Warks
Interesting thing with the hardware unboxed vid, you can only see these small differences with a 2080ti and 1080p, it's that close now. He said if you're using something like a 2070 you'll usually see no difference between the 9900K and 3900X in gaming now.
Caporegime
8 Nov 2008
I wondered why the test for that video was at 1080p then my brain switched on. So, if it's only about 6% at 1080, it must be negligible at 4k or ultrawide.
21 Mar 2012
I am getting a bit peed off with the intel is better at gaming trope from the YT reviewers I watch, it's at 1080p meh, it's not a lot, one's not unplayable awful whilst the other rocks. Everything on both sides is within gsync/freesync range, there's no difference really.
13 Mar 2008
Ireland
At best 5% average difference, even OC vs OC. I think the 3900X will age far better with bios improvements helping with the boosting issues, and as more applications and games use more cores.
Especially since if you can run the stock cooler, and even with PBO there’s a 1% difference. between getting a different cooler.
21 Mar 2012
Yeah, and put that 5% difference in avg and lows that are well within freesync range and you have zero difference. The recommendations should be on price. or just something else!
5% might of mattered years ago when we only had 60fps vsync, and being over that vs dipping under was maybe noticeable(?)
I'd like gamersnexus, jayz2cents etc to tell a 5% performance difference in gsync/freesync, there's none. So move on to something that matters, it's really lazy I find. Give me more Jim AdoredTV!
11 Dec 2016
Oxford
Well its definitely no longer "Intel is better in gaming". At best its "Intel 9700k and 9900k are better at gaming". Whole another story and you are looking at the top end of intel cpu lineup ONLY.
Even Ryzen 3600 eats the rest of Intel lineup for breakfast
1 Dec 2015
for me its 3 simple CPUs
3900x (x570 )over 9900k - editing / workloads/ streaming
9700k ( z390) over 3800x/3700x for pure gaming with high budgets
3600 (B450 ) over 3600x/9600k for mainstream gaming
21 Mar 2012
I have 3 PC's, all intel, so I'm not AMD fan boyying here.
Quick example then
https://www.guru3d.com/articles_pages/amd_ryzen_7_3700x_ryzen_9_3900x_review,28.html
Full HD gaming perf table. Biggest difference Far Cry 5, 122 vs 152. I think FC5 might have been updated now but anyway.
Gync monitor - Can I see the difference between 122 and 152? I'd bet 10p it's just smooth on both.
G J
G J
3 Oct 2008
The vast majority of Youtube vid's bench the 3600 against a STOCK 9600k/8700k and there's people fawning in the comments about how Intel got owned and then people point out but you can clock them pretty much to 5ghz which many of the Youtubers fail to mention.
13 Mar 2008
Ireland
Quick example then
It was World War Z that recently got a massive update. Brought the cpus to within 1-2% which is just margin of error.
Seems with Far Cry the engine itself doesn’t play well with Ryzen’s architecture yet.
