- 19 Feb 2011
Cancelled my 3800x order and just bought the 3700x, will wait out the refresh i guess and then look at options again. 3700x will be a decent ugprade over my 1700 anyhow.
Ordered a 3800X yesterday evening, just waiting for dispatch notice. The 3700X is no doubt better value, but I went for a 3800X. I'm hoping that it's binned in some way and that will eliminate some worry about losing the silicon lottery with a 3700.
Great news mate! Hope the afternoon goes quickly for you.3800x received! went to the gym at 6am this morning so i dont have to go after work. roll on 5pm!
Full new build 3800x, aorus pro, adata pro 1tb nvme, antec 850w psu, fractal design s2 vision, 16gb trident z rgb 3600cl16 and full custom water cooling setup using ek, blackice and bitspower products.
awaiting new refresh of navi cards before a splash out on gfx card so 7970 will be reused until then
So, it turns out, I can't completely turn off the power at the socket, otherwise I get a C5 code on the motherboard. Which then requires clearing the CMOS. Well played Asus![]()
Ramad@OCN said:I would like to Ryzen 3 owners with the C5 error code to try setting the following timings manually:
tWR: 20
tRTP: 10
tRDWR: 12
tWRRD: 6
Please try changing to these values and see if you still get the C5 error. Try also setting CLDO_VDDP to 980mV or 1000mV, I think this voltage is set to low by default.
The Ryzen Balanced plan has always had the minimum as 90%. Back in the day it was to avoid core parking, though AMD later said that the Windows Balanced plan had changed and improved to the point that Ryzen Balanced was no longer necessary. But then they brought it back specifically for Zen 2, so I'd assume it has worthwhile benefits. This is probably worth reading.Edit: What should the minimum processor state be in the Ryzen Balanced power plan? If I leave it at the default 90%, the idle voltage doesn't appear to drop (in Ryzen Master). If I set it to 25%, it drops to 0.9375V.
Might be worth giving this a try:
https://www.overclock.net/forum/11-...-vi-overclocking-thread-833.html#post28043662
The Ryzen Balanced plan has always had the minimum as 90%..
I've received my 3800x. I'm using a Asus CH7 motherboard with the 2406 BIOS. I've loaded the DOCP profile, which set the RAM at it's rated speed of 3600MHz. Went straight into Windows with no problems. Appears to be boosting to 4.5GHz on single core boost, 4.2 all core, which I think is right. Not done much else yet, so if anyone wants a Cinebench run etc., let me know.
Noctua D15s with 1x NF-A15 fan and 1x NF-S12A fan (using the S12A as I can't fit another A15 on the front, due to RAM and not being able to put the side glass back on)4.5 our of the box sounds promising. What's your cooling?
I'd updated to the latest BIOS (which is awful) on my Crosshair 7. Latest chipset drivers on Win10 1903. Took my 2700x out, put in the 3800x, heatsink on. Boot, into BIOS, set DOCP standard, into Windows and was boosting single cores to 4.5GHz, all core around 4.2GHz. No tweaks, no change in voltages, no reinstall of Windows. I've ordered a MSI X570 Ace as I'm not prepared to wait for Asus to release a BIOS that isn't full of bugs.dang... my loop might just get me a bit more then.
What was your install process? Just slapped it into an existing install or the whole "1903 full reinstall, new chipset driver fresh install, new bios, etc"?
Any tweaks to voltages/etc or completely untouched stock performance?
also: i see your on Asus - crosshair 8?
And is switching from 2700x to 3800x worthwhile?
