I'm not sure about the PC-O11 ROG but there is an ASUS Rog Strix case called the Helios currently being worked on. https://www.asus.com/ROG-Republic-Of-Gamers/ROG-Strix-Helios/Hi,
Does anyone have an update on this yet ? Starting a new build and really want to use this V2 case.
.Not a bad choice, however some of the review saying airflow is a little low on front panel only being able to pull from the top and bottom, Ideally I was planning 2x360 1 top 1 front or even 1 480 and 1 360..
Seems only newegg have in stock, Do you know if OcUK will stock this case and if so when.
I did hear back from Liam Li and they recon around COMPUTEX this year so end of this month mid next for the WGX ROG v2
The first link you provided is the closest to release version, the second one was a prototype that they were still tinkering with. I still do not think that first link was 100% finalized but it should be much closer to the production model. The O11 Dynamic XL is the same as the ROG V2, they just changed the name to be more explicit that its basically just a bigger pc-o11.
There is still ROG branding, but it is much less in your face, its a ROG decal on the corner of the left side tempered glass side panel.
That price though XD.So another Australia site has the White XL listed and with better photos. https://www.scorptec.com.au/product/Cases/ATX/77904-PC-O11DXL-W
Slightly concerning is the side radiator/fan cutout, as it looks like it'll only accommodate radiators with ports closer to the middle such as EK rads, rather than the XSPCs radiator I have...
When can we expect pre orders?
Also am I being silly for getting this case if I do not plan on watercooling in it straight away if even ever?
