- 18 Oct 2002
Do AMD have any plans to release an RX580 replacement based on the Navi architecture?
I actually don't think most, or any for that matter, of the press is paid off. I just find most of them completely incompetent or superficial in their testing.
If you mean cheaper than the 5700, then yes, I expect so.
They've already replaced Polaris tier wise
And?
I think he may be looking for a Navi card that's cheaper than the current two card lineup, I think there will be one, so that's the answer I gave him.
The 5700 replaced the rx580
The 5700xt replaced the RX590
The xxxx will replace the rx570
Surely it's the 5700 that's replaced the 570 and the 5700XT has replaced the 580.
The 590 is a nothing card. Just a higher clocked 580?
Whereas the 570 and 580 are actually different. Like the 5700 and 5700XT
Then why did AMD called the 5700xt the RX690 in it's marketing material just before E3?
https://www.pcgamesn.com/amd/radeon-rx-5700-xt-690-graphics-card-e3
)Errr NO. The "replacement" is twice as fast with double the price. That is not what we call replacement.
5700s are replacements for the Vega cards. Faster and at lower price points on release. (V64 MSRP was $499 and V56 $399). (some might argue it replaces the RVII at $699)
There are going to be 5600 series Navi that will directly replace the Polaris chips at their price points ($170 & $250) with performance bumps.
The 5700 XT is also pretty close to the Radeon VII in gaming, whilst being significantly cheaper, which doesn't strike me as something an RX 580 replacement would be doing!
You've obviously not been into PC's much then.
There's loads of examples of the new generation mid range on a die shrink performing as well as previous flagship.
If we started following the logic you're suggesting we'd be paying more and more every generation
Rude! I've been into computers since the mid to late 1990's, but thanks for proving that once again you can't enter a discussion without coming off as puffed up and overbearing!
You know what, why am I even engaging with you? Ignore lists exist for a reason!![]()
They replace the vega line up, the amd roadmap always stated that.Rude! I've been into computers since the mid to late 1990's, but thanks for proving that once again you can't enter a discussion without coming off as puffed up and overbearing!
They've already replaced the card he's specifically mentioned.
It's just at a higher tier price point.
A lower tier product isn't a 580 replacement.
