No idea mate i am not responsible.
I know you aren't responsible, makes no sense NV posting 7000 (doubled is effective ram) and AMD showing 875 which has 16x multiplier.
I will check after tea.
The 5700XT only needs 8% beyond where I am and it basically matches the 2nd fastest 1080ti produced in a synthetic.
So pointless moving to a 5700xt unless its just to play with new toy performance wise sounds like equal or lower?
I'd wait for AIB models but is certainly consider it worth it.Have any of you guys upgraded from a Vega 56, worth it?
I'm thinking mainly for VR.
I upgraded from my old Vega 64 which is now in my son's pc, for a sapphire 5700xt. I didn't "need" to change it, I wanted to change it to have summat to play with (I've got a morpheus sitting waiting to be used). Theres not THAT much performance increase, but enough to be noticeable and its a nice addition to my 3600x.
Much overclocking headroom on your 5700xt?
My Vega 56 is ~1640/1000 so probably close to a stock 64.
(assuming those are wattman frequencies rather than in-game)Have any of you guys upgraded from a Vega 56, worth it?
I had a Vega 56, and I can honestly say that the 5700 XT is a big step up. I play at 4K, and refunded my Radeon VII, so that gives you some idea!![]()
I didn't even realise there was a VII - what is that thing?
I play at UWD so just shy of 4k, but my VR is essentially 4k and Vega 56 starts to sweat on VR.
The Radeon VII was a repurposed workstation card, so not entirely gaming focused. It was good for 4K, but it was expensive, and the 5700 XT is over £200 cheaper for a similar level of gaming performance.
Basically AMD were trying to match the RTX 2080, but using a card which was more suited to professional applications than gaming. It's a good card, don't get me wrong, but if all you do is game then the 5700 XT is the better choice.
I see, thanks for the clarification - the VII had slipped me by!
Are there aftermarket coolers for the 5700XT yet? I have a Raijintek Morpheus on my Vega and it's a-m-a-z-i-n-g.
Literally silent, even at full tilt.
Stick Morpheus on the 5700XT
Does it fit okay, sounds from your post above it's not quite right?
There's a similar thermal pad (although im not sure if it is as good) as the one used on the Radeon VII available on the rain forest. Not sure if OcuK sell it as well, but might be worth getting that one and cutting it down a little to fit the die.I'm still struggling getting a decent junction temperature with the Morpheus
The pad I bought wasn't what I thought it was either.
I did a quick run because I was concerned and it came in about 77C where previously it was much higher so I've improved it.
Going to try another remount slightly differently this time to see if I can improve it.
Once I've sorted this though I can actually bench the damn thing
