- 22 Feb 2014
so I had 2130 score earlier on cinebench (r15) with my 3700x.
have changed a few settings in bios and the score dropped (even though the cpu was showing a higher boost)
changed settings back again and score still hovering around 2000.
Bit confused to say the least.
At the moment I have
enabled PBO
set mem speed to 3600mhz
set fclk to 1800 (doesn't seem to be automatically changing with ram frequency)
set cpu vcore offset to -.15 (tried -0.1 as well)
Also a question with regards to manually overclocking, the only way I can see to do this is to manually set the multiplier, but when you do this the CPU doesn't clock itself back down when its idle, it remains at the higher speed, is that right ?
enabled PBO
