Good luck. It's brought me pleasure messing around with the chip. Much better than I expected to OC.
Thanks
Look at the previous page, I got 5345 on 1st attemptSince no1 is beating my mc, gonna do it myself 5340
u got 3800x, not fairLook at the previous page, I got 5345 on 1st attempt![]()
Haha I was just testing, to be honest I havent tried since. I dont really want to push too hard and brake a new CPU.u got 3800x, not fair![]()
You, get in DiscordNo point having it if you don't thrash it. Ryzen is pretty good at looking after itself![]()
4425 MHz (through Der8auer tool) voltage auto. Just done 516 sc (booooooring). So when we going to see you crashing the party with your new shiny ?Clock speed?
Hope you holding off for 3950x, would be a crime to waste such a cooling solution.
I dont really want to throw 1.5 either, even if it is for some benchmarks :/ What temps were you getting benching?haha 3700x and the crappy stock.
I can bench at 4500 on CB but it's only giving 518. I'm worried about damage as it's at 1.5 volts for it. The Noctua should arrive tomorrow. I'll see if I can attack your MC scores then![]()
Nice, you got good chip by the looks of things. Try ccx tool oc, while leaving voltages on auto ( don't put to high MHz, just a bit higher than manual )
You said 4.5Ghz with a 2700x!2700x @ 4500GHz (4.8v)
Not sure I could get any higher without an electrical issue. Don't want to damage the chip!
