Does Realbench use avx instructions
14 Oct 2007
newcastle
Does Realbench use avx instructions. I have been running 5.1ghz with no avx offset and I have been playing around with the offset to reduce temps during the summer with my house being very warm 25c+ and have noticed my chip downclocking to 4.8ghz with a 3 avx offset. Does anyone else use an avx offset with there 9900k?
Gigabyte master
I have the pro wifi.
Realbench uses some occasional avx instructions I believe.
Problem I noticed was my CPU was constantly down locked with an avx offset. I only use my rig for gaming so had turned off the avx offset now.
@Danny75 also informed me that gigabyte avx is currently broken and just permanently downclocks.
If it does, then it doesn't make much difference to temperatures, maybe a couple of degrees. Compared to Prime95 toasting everything.
