- 9 Jul 2012
- Nottingham
Watch Navi outshine rtx series cards at ray tracing
One can wish right?
One can wish right?
One can wish right?![]()
I think it will easyThe Hybrid patent AMD got, might be able to pull that through.
Anyone with Navi 5700x and The Division 2 plus 1440p can you run Ultra preset please, with under Video options DX12 enabled and Lower latency setting.
The Navi GPU can be undervolted.
Would be a plus if you had i7 8700k at 4.7 all cores
Thanks in advanced.
Not only that, but the card is 4 slots high and passively cooled by extreme through-draft!
This is what a blower card could be if manufacturers got off their ass.
4.5 slots thick, extends above the PCB, enormous surface area, much mass and a great big fan (not pictured) to shove a ton of air through without noisy RPM.
Wait until tomorrow, 8600K would suffice?![]()
Nah, it's horizontal. But it's a so-called "MPX Module" that presumably has weight support at both ends rather than just one.This is for vertical installation not horizontal.
looks like Radeon is indeed gaining mindshare this go around.
I've personally recommend the 5700XT to two people in the real world however
And they both went out and bought nVidia![]()
Yeah that should be fine thanks
Hmm, I do wonder why this wasn't a PC video as the original was.You know that was probably running off a 2080ti PC right
Back in the early 2000s, a bizarre thing is that the Xbox360 developer prototypes were actually standard Apple PowerMac towers, because they had a similar PowerPC CPU and ATI graphics.From what I've recall about last gen was that they put the console hardware in an actual PC case before the final design.
