From what I read it is intended to use 90% as the minimum, because when they are not in use they go to sleep instead. However that should not be causing the CPU to Idle on high voltage, so they recommended to use Windows on 85% if your Ryzen Balanced is not working.
Yeah I read what the AMD had posted but wondering of everyone who has installed fresh with latest chipset drivers what is your min proc setting under Ryzen balanced ? mine was 90% with the old drivers but with new its 0%, as new obviously didn't install correctly over old on mine despite no obvious signs they hadn't. even had the successful message but I didn't have a Ryzen high performance profile hence the doubt.
