got a link for it? googled '10000 Aircon' and no hits.
I am still waiting for someone to invent a portable aircon unit that doesnt require house modifications to use.
Searching for '10000 Aircon' on currys says nothing found.
That's only 5,000......our bedroom is 15m
This one is also very good
Blyss 9k BTU
: https://www.diy.com/departments/blyss-mobile-air-conditioner/3663602439943_BQ.prd
I did some research and these two had the best results from families.
Screwfix sell a 12,000 one for £299 but all out of stock
Currys is the logix one (unsure if its any good)......
This one looks good though
https://www.climachill.co.uk/product/pac12h-kyd32-12000btu-portable-air-conditioner-cool-heat/
No point buying one now. It'll be raining again by the time you get it up and running.
I'm going to look into getting one for next year though, maybe even a proper one installed, buy it in the winter when its half the price.
The one from currys above is 2.9kw (~10000BTU)
https://www.currys.co.uk/gbuk/home-...19-portable-air-conditioner-10191206-pdt.html
We have the predecessor to this, it's very good. However, it is not nearly as good as the proper split system elsewhere in the house. This is my little process that I follow to get the bedroom ready:
1) Use a Prem-I-Air High Velocity Air Circulator Fan to get the room less stuffy, normally 30 minutes does the trick. This step is key, without doing it the A/C is crap.
2) Shut all windows and then plug in the portable A/C and let it go to work for about 45 minutes.
3) Walk into a room that is significantly colder than the rest of the house.
4)????
5) Get a good nights sleep.
I bought one of these last year, £299 plus VAT, awesome, think I'd rather buy an A/C unit from an A/C specialist. The sleep function is the best bit, it slows the output and reduces the noise till it eventually turns off hours later.
https://srw.co.uk/acatalog/PAC-C-12-Mobile-Air-Conditioner-3-5kw-R410a-142806.html#SID=30
Where do you vent the hot air? out the window or have you drilled a big hole in the wall?
