Caporegime
- 18 Oct 2002
There's info out there about a 128 cu navi on the cards, isn't there?
I heard it was 256CU with a 1000w power ceiling. In fact power requirements don't really matter any more, obviously.
Be aware of a new troll, added to my ignore list.
So, someone that disagrees with you then.![]()
Wonder if he's close to the 500 limit yet
You're all welcome to him
Been on here since the '99 boards, I've seen many many idiots come and go. I'll still be here when this one goes![]()
I have a feeling I'll be on his list before too long, which is just fine by me!![]()
Stock 5700xt is about 2100rpm.. pretty sure that's not 20% fan.
We are talking about load scenarios. No review in the world is reporting 20% fan stock settings in actual usage.
Example, stock, in-game, 2100 RPM:
Mea culpa. Indeed is it around 40%. Yet still is not that loud the actual fan. The moving air is, is not the high pitched noise from eg the 290X and V64 blower fan at around 40%. Let alone the Noctua Industrial 3000s.
The latter are very very loud even at 40%. And I know it for the fact that had 2 on the Morpheus II on the Vega 64, after the Predator 360 pump died in May.
It's certainly quieter than the Vega 56 blower I used to have, which is a big improvement.
It's certainly quieter than the Vega 56 blower I used to have, which is a big improvement. People just need to stop putting their computer cases level with their heads, and all of these noise issues will go away.![]()
Load temperatures were around 75°C. Now, they are not below 90°C. This is not an improvement.
"Idle temperatures are excellent even with the fans turning off in idle. Gaming temperatures are better than on RX Vega 64 due to the reduced heat output. I think given the 75°C under load, AMD could have adjusted the fan profile to be quieter, allowing for higher temperatures."
https://www.techpowerup.com/review/amd-radeon-rx-vega-56/36.html
Is the cooler inefficient and seems doesn't sit properly on the GPU yes. However even on a better cooler this heat needs to move.
The chip is tiny, is half the size of the RTX 2070/V64/1080Ti/290X more than half the size of the RTX 2080, yet while it burns less power is not that much "less" power. So "we" expect from it to dissipate 180W-200W worth of converted electricity to heat twice as fast as if it was made with 14/16nm process. Something impossible until science comes with a better material than silicon.
Imho AMD & Nvidia should start considering big IHS with indium soldering on all their 7nm and smaller GPUs.
But seems everyone in the "tech world", forgets the First Law of Thermodynamics. Some times I truly believe that the significant majority in here didn't do Physics or Mathematics at school.
Some didn't even do History.....![]()
But we haven't reach full inception yet. We must go deeper...Well, I use the information from AMD that RDNA 1.0 | Navi 10 is not full new gen architecture but a hybrid between RDNA and GCN https://wccftech.com/amd-radeon-rx-5000-7nm-navi-gpu-rdna-and-gcn-hybrid-architecture/
WCCFTECH says Navi 20 but if it's full RDNA, why would it be called Navi and not something else? And what else is it and why is it being hidden from the public as a name?
Actually, Polaris 10 | Polaris 20 | Polaris 30 is one and the same thing.
Vega 20 is an optical shrink with minor changes of Vega 10.
So, Navi 20 should be the same Navi 10 with improved clocks.
If they can't make cool 250W cards or if they don't want to, then design 50W chips with the same performance.
My original X1600 Pro was a 40W card.
To put in perspective 2080 has 13.6 BILLION at 545mm^2
Got my 5700XT Today, Gigabytes version- the design in person is stunning.
Now I am waiting on the block from EK![]()
